RADIATOR IS LEAKING!!!!
SHO SPD
SHO member #480
Naples, Florida
Ok, when I am just letting the car sit while running some Antifreeze seems to be leaking from the radiator, I cannot pin point the exact problem, it is inside the fan cover just above the Radiator drain plug, not too much leaks but enough to see it. Is there another plug that could be loose up inside there??
1989 Titanium pearl
CAI- Thanks to justinrsho
K&N cone filter
G-tech times
0-60....6.61 sec.
1/[email protected] MPH
"Dont tell me, SHO me!"
[This message has been edited by SHO SPD (edited 11-19-2001).]
Blast7
Rochester, NY
It is really difficult to find a spot on the radiator that is leaking without actually taking it out. I had a leak in my radiator and it looked as though it were coming from teh part where the plastic meets the metal core, but when I took it out the plastic part of the radiator had a crack in it. A new radiator cost me $150 from Autozone.
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
Rod Shifter
Blazer Tech Fogs
Want to Buy:
~1st Gen Black rust free trunklid
~1st Gen Black rust free front door mouldings
If yours is the stock radiator with the drain petcock on the driver side end tank, you probably have either a leaking end tank to tube section seal or a cracked end tank. The seal between the composite end tank and the aluminum tube section can definitely produce a leak. I have had the end tank crack near the upper fan shroud bolt on the driver side, causing a leak that only replacement of the end tank or the whole radiator would stop. I choose to replace the radiator after its 150,000 mile lifetime.
Scott
1991, 252K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
[This message has been edited by sdpatt (edited 11-19-2001).]
BeatDaSHO
Hatboro, Pennsylvania
yo man. I just had the same problem. It didn't seem like a lot of antifreeze was leaking out. I kept finding little antifreeze puddles under my car and i could see it was leaking from somewhere on the drivers side. I took out the fan and i started it up and a whole crap load of antifreeze just started pouring out. I took out the radiator and had it patched. cost me 75 bucks. good luck boss. Later
Greg
RStalveyARFF
too many shos
Georgetown, MA
I have a leak in the same exact location. Replacement radiators are going for 89 bucks on ebay all the time, I think it's more of an annoyance of topping off the resevoir and seeing puddles if anything.
T
Tommy the Greek
Guest
The other day I replaced my radiator as well because it was leaking the same way yours was, right where the aluminum ends. It was doing this actually for a while until I saw it actually driping on the ground. I wanted to put a factory unit in but because of time and money I put an aftermarket radiator.
P/N: ACF2372 List- $319, Cost- $110
Then refilled her up with Toyota "red" antifreeze P/N 00272-1LLAC-01.
'95 SHO ATX, 55W foglights, coneless, fishtank mod, white/mocha cloth interior, 45K, Mobil 1 10W-30, build date 12/13/94.
Below is a pic of her @ 28K miles (Nov. 6, 2000)off interstate 87, overlooking Lake George, NY.
www.roushind.com
SHO SPD
SHO member #480
Naples, Florida
Ok, I will probably just go with a new radiator, thanks guys..
1989 Titanium pearl
K&N cone filter
G-tech times
0-60....6.61 sec.
gregr
Orange County, NY - USA
Same problem here. I noticed it yesterday after replacing the Oil pan gaskets. Driver's side is leaking somewhere. Not a lot, but a little at a time.
Greg Raciti
SHO Forum Webmaster
93 Emerald Green MTX
Performance Plus high flow stainless Y-pipe
Scott 2.5" Mandrel Bent Stainless
Exhaust with Edelbrock mufflers
SHOShop Cold Air Induction
SHOShop Underdrive Pullies (to be installed)
Romar Enterprises Subframe Connectors
SHO NUT Performance Aluminum Subframe Bushings
24mm front sway bar
26mm rear sway bar
Energy Suspension poly bushings
JimN696
Morristown, NJ, USA
I can't find a leak in mine, but I smell coolant once in a while when the engine is hot. I am thinking it is a small radiator leak because I haven't had to add coolant in about 2K miles.
RStalveyARFF
too many shos
Georgetown, MA
if you smell coolant when the engine is hot, then you either have a leak onto the cats, the water pump is leaking, or your upper radiator hose or crossover tube has a leak.
