Quick Tire Question
Calypso
**** Deer
Grand Rapids, MI
Hey I just had a quick question. Does anyone know if a 225/45/17 would fit on a borbet type-e rim? I am currently running 235/45/17 but not sure if the 225 would fit or not. I've got a flat tire and found these tires for CHEAP so wanted to know if they would work or not...
Thanks in advance for any help...
shobote
Naperville, IL
what tires are they ? they should fit the rims but are a smaller diameter than OEM so speedometer will be off, and also shortens the final drive, similar to as if a shorter gear diff was used, so gas mileage will suffer a little.
platoribs
Live to Drive
Plat0ribs House of SHO,il
I am currently running 235/45/17 but not sure if the 225 would fit or not. ...
Sorry I got nuthin on your question, but I'm curious, I'm currently running 245/45-17's and have rolled my fenders and messed around with thin (5mm) spacers to get interferrence free rolling.
How does the 235/45-17 fit?
K-Dawg
Treasure Coast, FL
Yeah they'll fit. A little short for my tastes, but a lot of SHOs are sporting that size.
Is that a fact or speculation?
shobote
Naperville, IL
Can't defy laws of physics; shorter tires equates to shorter gearing so you'll get a little faster accelleration along with lower mpg. Taller tires results in the opposite.
Calypso
**** Deer
Grand Rapids, MI
Yeah the 235/45/17's fit fine. I've got Intrax springs and the rear wheel wells are cut/rolled a little bit but not too much. The only time they rub is if someone is sitting in the back and I go over a bump. Sometimes it'll rub over big bumps/dips without someone in the back seat, but not alot. The tires are tucked up in there though...
Thanks for the help guys. Picked up two tires this morning for $15. Can't beat that...
