Start here:
https://blog.headlightrevolution.co...FOVldLruybJTO4v9grQaAmCnEALw_wcB&gclsrc=aw.ds
many of the brands are cheap on Amazon.
Headlight replacement for many SHO owners requires or is difficult enough for taking the bumper off. If you are going that route replace the headlights.
I have NOT found different aftermarket designs that have cat eyes etc. If anyone knows a place they can share.
My two cents - replace both headlights and bulbs same time - save up.
PS there are LED replacements here and there - my two cents not worthwhile. The xenon diamond design produces a targeted central beam without getting weird optics of a split design of LED - 2 LEDs on two sides of a heat sink, led and the lumens are usually similar. Stick with the xenon. My suggestion is buy and watch videos from diode Dynamics,
Find the right bulb for your vehicle! We have a wide range of LED light bulbs for your truck or vehicle!
www.diodedynamics.com
High-intensity discharge (HID) headlamps produce light with an electric arc rather than a glowing filament as you might find in a standard halogen bulb. The light itself comes from an arc of electricity, facilitated by metallic salts that are vaporized within the arc chamber.
Sent from my SM-T860 using Tapatalk
