QUESTION! strut tower brace...
rpmshotimeeh
Its SHO_time!
MA
i have one of the rear strut tower braces :dribble: and i would like to throw it in however i had 1 concern. i just got my car alligned about a week ago and do not want to have to pay and do it again. i was wondering is it possible to install this rear strut tower brace and guaranteed not to screw up my allignment? i was hoping to do it tomorrow durning the day in the sun and scorching heat. and i need to find a cheap neon 1 for the front so i have a stb in the front too :thumb: lol thanks in advance fellas'.
~ERIC~
SinisterSHO
Rust free
630, IL
Depending on how they mount, if they only use two mounting points, you should be okay. Being that the rear struts use three points, the one bolt should hold the location. However, I think that most of the alignment in the rear is done with the control arms, but I might be wrong on that.
K-Dawg
Treasure Coast, FL
If the brace is adjustable, don't "adjust" it too much and you'll be fine. Otherwise, just bolt it in and you'll have no problems.
rpmshotimeeh
Its SHO_time!
MA
what if it is 3 does that mean im screwed lol? what would happen if i through it on ontop of the nuts that are already there? would that still work the same or no??? help lol i want to do this but dont want my allignment to suffer.
rpmshotimeeh
Its SHO_time!
MA
to k-dawg...so if i adjust it up while they are still bolted down and then unscrew all 6 nuts throw this on and tighten em up it will not affect my allignment at all?
K-Dawg
Treasure Coast, FL
Its pretty simple. You're not going to change the alignment. There's really no alignment adjustment in the strut towers on a stock SHO. Loosening the nuts won't change anything.
Bolt the brackets onto the strut towers, adjust the bar until its snug, then lock it down with the jam nuts.
rpmshotimeeh
Its SHO_time!
MA
ok thats all i needed to hear thank you very much k-dawg i appreciate it man.
Shoaz
Studly dood
Scottsdale, AZ
Ditto, just for confirmation. Unless someone has hacked out the mounting holes to provide more camber the nuts can be removed without affecting the rear alignment. Even if the holes _are_ hogged out you can probably remove the nuts and install the strut brace if the car isn't moved while you're doing it (which would be typical).
Since the rear alignment is done at the control arms rather than the strut tops it should be no problem to install the brace without affecting anything. FWIW, I've replaced rear struts without affecting the rear alignment... :cool:
rpmshotimeeh
Its SHO_time!
MA
ok done seems to have stiffened it up a TON now all i need is one of those front stbs off of the neons to put in the front to finishi it off...what else is recommoended for a sweet handling car yet still very comfortable as in not a ton of noise or a ride like u have no suspension?
