There is a hard continuous rubbing sound coming from the front/right suspension area. The noise has been there for about a month and has gotten increasingly louder and the vibration can be felt through the accel. pedal. It's not the rotors or out of balance tire. You hear the noise and vibration after about 30mph.
To make sure it wasn't the tire, I put the SHO spare on and drove it. The noise and vibration slightly went away, but I'll conclude that the tire isn't the culprit.
The sound and vibration goes completely away if I even ever so slightly turn the wheels to the left. Turning the tires to the right doesn't seem to make a difference in hearing the sound.
Parts replaced on that side within the last month are: outer tie rod end, stab. bar link, and lower ball joint. But, the noise seemed to be there before these replacements. Wheel bearing?
A mechanic said the strut plate was loose while doing some other work, and I was wondering if this could cause vibration and the hard rubbing sound? He also said that I had a shifted steel belt in one of my tires, but I didn't ask which tire!
So, what would cause this vibration under driving, particularly when I turn the tires, even slightly to the left, which makes the rubbing sound and vibrations go away?
Help!
Help!
