Question About Livernois Tune Package
SharpSHO11
Thinking about running a Stage 2 Livernois Tune in my 2011 SHO (it has the PP) is anyone running this tune "Without" the 160 Deg. Thermostat? If so how much better is the performance?
SHOnUup4
SE MI
I've ran with and without the tstat...highly recommend it.
Good 10* cooler temps on the big end during 1/4 pull.
Rich
SharpSHO11
Thanks yet again Rich. The reason I ask is I have the best warranty I can get on this SHO (Being its my daily driver) and I know I can pull the Livernois tune out and put the stock one back in if I have to run it into the dealer for work but not as easily the T stat.
Doug
SHOnUup4
SE MI
Tstat shouldn't be noticed under most conditions.
Stock tune will be fine with it in also.
But, if for some reason you have a major failure, Ford can find the tune regardless of it being flashed back to stock.
Just maintain a thorough maintenance schedule and you should be fine.
Good luck on the venture, and keep us posted man.
Rich
thatSHOguy101
