Quaife Install
92ShoOff
Tall Timbers, MD
Hey guys, sorry for so many posts lately but I've been trying to decide what I was going to do about my tranny that just recently went out on me. Well my parents are making me take the car to AAMCO to get the work done because they're tired of letting me borrow their cars for work. AAMCO told me that to install my new clutch wouldn't cost any extra since they'd have to tear the tranny apart anyways. I was wondering, if I order a Quaife and the shim kit, how much do you think a shop like that might charge to install it? I don't know what the tranny looks like when it's apart, but I'm assuming the differential is right there and can fairly easily be removed. Beth (Bizzy) was explaining to me about drilling out the rivets (I'm assuming to remove the ring gear from the factory differential to put it on the Quaife). I know AAMCO is going to ream me in the price for all this labor, but I unfortunately don't have enough time to send the tranny off to someone else to have them do the work for me. Do you guys think they could charge all that much more to install the Quaife if they already have the tranny torn apart??
Thanks guys!
yamahaSHO
E85 whore
Arkansas
Not sure on the charge as they have to drill the rivets for the ring gear, pull one bearing off for the speedo gear, then install the speedo gear, ring gear and press two new bearings on. Then they have to shim the differential. If they don't have the ford tool, they wil have to use something like solder to get the correct size.
Here are the internals with the Quaife installed.
Solder being used to find shim size...
