Putting in a UDP. What else?
LOUDSHO92
Sponsoring Vendor
Rancho Cucamonga, CA
The strut tower braces can still work, you would need to grind out some extra clearance.
The subframe connectors are a huge gain to stiffen the entire body. You could jack up the car with just 3 jacks.
Binghamton, new york
Ive been looking around and planning my next order for the past couple of days. Im thinking it will be something like this
-Keystone body stiffener kit
-Sho Nut aluminum subframe bushings
-a bunch of misc. bushings
LOUDSHO92
Sponsoring Vendor
Sounds fine. Just make sure you know which bushings you need versus what you are ordering.
jayro
Auburn, In
Like LOUDSHO92 said, sub-frame connectors are great.
If you are pulling the sub-frame to add the aluminium sub-frame bushings I would put in a smaller front sway bar. I have a 20 front and 26 rear. For my setup it is very balanced with a slight bit of over-steer at the limit, but opinions vary depending on the car and driver.
I have a rear STB and like it. I have heard from a number of people that have before and after experience that the front STB increases push in the corners. Our cars are already nose heavy and tend to push. For that reason I chose to not install a front STB.
My next mod will probably be a Gen3 sub-frame............ unless I can talk myself into bigger brakes and a turbo kit. I am not sure how my current NA set-up would mix with boost.
I say the seats would look fine....but then your asking guy who has removed most of his interior..
