pulling sho engine and tranny
1992blackmtx
cleveland,ohio
i was wondering where the best spots to lift the engine out of the car by. the intake is already off the engine, and know of the one bracket on the front of the engine by the alt. and need another spot to lift from. thanks for the help.
it is a 3.0 if it makes a difference
1992 Black mtx, dynomax catback, 73maf, k&n, superchip, konis, eibachs, shonut aluminum subframe bushings,romar subframe connectors, 225/50-17 nittos on loco #143
what means the world to me?? breakin laws, racin cars
SHOBLOOD
Tama, IA USA
When I pulled my motor I used the Rear Exhaust manifold. I took a chain and rapped it aroung the manifold and used the front hanger. None of this do I accept liability for if something happens to you though.
Good Luck
ROB
91 MTX Sho Plus Green
91 MTX Mocha
96 ATX Purple Haze SHO
Sho Brotherhood of Iowa
RStalveyARFF
too many shos
Georgetown, MA
when I lifted it for it's clutchwork, I stuck a bolt through the bottom right intake manifold support bracket hole. It worked good, until the bolt snapped, so use a grade 8 bolt or at least something very strong. Supposedly there's a ford lifting eye that the technicians screw in somewhere to pull the engine. Might as well go down to a ford dealer and ask a mechanic. Their HELM will tell them the part number of the eye and where it goes.
SLOSHO89
San Luis Obispo, CA
When I pulled my motor I took off both the front and rear exhaust manifold(yes the rear does come off without pulling the head) and i put a chain from one side to the other and bolted it to the exhaust studs. Worked for me..... Good luck
Make sure you paint your valve covers and intake while it is off!!!!
Oxford White '89 SHO
Slicers, SHO+ hood and spoiler, Met.-Red and Gold Intake.
Web Page www.geocities.com/web_page66/
ShoGuy93
Yes I Have Blue Rims
New Palestine, Indiana
You just really have to stick it out there to paint them don't u
but i would too if i had mine off
Brad
93 Sliver ATX
SS cold air snorkel with k&n fliter, superchip, flowmasters 40 series, pp y-pipe, Performance Friction Carbon Metallic Brake pads, Pilot fog lights, Kenwood excelon cd player and 10 dics changer. 5% tint all around! Ford Motorsports decal on windsheild, and Blue sho reflective lettering on the body.Blue, Yamaha inside stickers. Blue, SHOForum.com sticker on back window. Ford emblems on my back triangle window with racing decal under it. So it says Ford Racing!! Indy Tags: SHODU
Looking for a Sliver or Black MTX with low miles!!!
RStalveyARFF
too many shos
Georgetown, MA
for the 10 minutes it takes to take the intake off, you better believe I'd be painting my intake!!! Oh wait, already done!!!
[This message has been edited by SHO91MTX (edited 10-27-2001).]
