Ptu and axles
RubySHO
not
2014 sho non pp. Needs front axles and ptu is on the way out. figured id bite the bullet and do it all in one go. part prices are crazy. there is a police intercepter same year at local pull a part yard. will those parts be interchangeable?
I would be willing to bet they are interchangable.
Ta2dResqr
Central Ohio
The easiest way to know for sure is to look on a site like Tasca and find the factory part numbers. Then check fitment for other vehicles that have the same fitment. You can also then google the factory part number and see what pops up for fitment/applications. You can also compare the same way with an aftermarket part as long as you trust the part supplier. That being said, axles are $60-120 a piece depending on the brand. You may want to consider new axles depending on junkyard cost and mileage. Especially an FPIS application that was more likely to see hard/abusive mileage.
RubySHO
not
definenitly something i will consider. .The only axles I have food with good reviews were about $200 and delay for shipping. Thank you
