PS rack problem
JonVH
Norwood, MA
My '93s power steering has always been a little spotty, works well then hardly at all then fine all in the one 90 degree turn. I lived with it fine so far, but now it's vibrating rather loudly & you can really feel it (again intermetintaly in a 90 degree turn). Does this mean the rack is going or is it a pump, fluid or a sensor problem?
Is the rack/pump the same for any Taurus or is it unique to the SHO? Also is it a speed variable assisted unit?
Thanks in advance.
MilTownSHO
Horicon, WI
The power steering rack apparantly blew on me last tuesday. Well the new rack from ford for me was 215 bucks since I work at a ford dealership so you better hope thats not it. I got a used rack for 75 bucks from a junk yard though. The rack from a SHO and a regular taurus are different in the length I believe. I am for sure they are not the same anyway. I do also believe that they are speed variable assisted. I would get whatever it is checked soon because if the rack breaks your stranded and its no fun to be out of a car... especially an SHO...I get mine back tommorow I cant wait...o and labor if its the rack is 5.5 hours plus alignment...which isnt cheap either...i got it fixed for 200 though luckily....good luck
<small>[ February 24, 2002, 11:19 PM: Message edited by: MilTownSHO ]</small>
I am not sure what year that the VPS started being fitted to the SHO, but I know you can get a rebuilt rack relatively cheap through O'Reilly Auto Parts or Auto Zone. Check around with your local stores for the A1 Cardone rebuilts. I recently installed a rack for my 1991 that cost me only $79.99. I installed it myself, but would gladly pay someone $150 to do it for me. The rack in the SHO is SHO-specific.
