platoribs
Live to Drive
How does one go about replacing the PS hose on the pump side?
On a scale of 1 to 10 how much of a PITA is this?
$15 harbor freight "Serpentine belt wrench" would be your friend mike.![]()
It's about two feet long and you can put crow's foot wrenches on the end of it. Access...
Probably be better if you removed the hood.
I'm going to try putting a compression fitting on the where the two cometogether, if that works it'll get me through a track day Monday. Then I can tackle it the right way with a new hybrid hose.
This.Having had the fire department come out to help extinguish a power steering fluid fire on one of the competitors cars at an autox, I urge you not to do this. It is a high pressure hose, meaning a couple thousand PSI IIRC.
Take the two new hoses to your local hydraulic shop (e.g. Parker Hannifen). Have them adapt the Gen III rack end to the Gen II PS portion, such that the overall length stays the same as the Ben II. Or I think NESHO has a hose kit for this swap.
