2011TAURUSSEL
2014 SHO LMS Stage 1 V10
After all the discussion both on and off the forum of the possibility of getting stuck in a NON 93 Octane area it finally happened. I was in Tulsa, OK and doing my final top off for the final leg back to Dallas-Fort Worth after the Ford Nationals in Carlisle, PA. I was stuck with not enough to get back to DFW or for that matter even Oklahoma City which was the next even closest available 93 availability. Best I could get in the area was 91.
I made a quick to Jaimie and get some over the phone technical assistance/guidance. I advised of the problem, with getting 93 and although not recommended Jaimie advised 91 is possible and will work.
The performance restrictions were explained as in no WIDE OPEN THROTTLE, expected fuel mileage decrease and of course reduction in fuel tank range. The high ambient temperatures didn't help, but the tank worked. When I did initial highway acceleration I used the Cruise to "trim" the speed which is my normal cruising speed method. I definitely felt the performance restrictions and reduction in tank range. The trip was successful and no M.I.L. codes. I will be heading out to Costco to refill first thing in the morning to dilute the leftover 91 and run a couple of 93 Tanks back through the system.
Conversely during the trip from DFW-Carlisle I topped off just inside the MO side of the MO/AR border at a Valero 93 Station.....again one of the few in the area. I was easily squeaking out 450 miles and if I didn't have to clear the interstate for trip segment completion I believe that the range on that tank would be over at or very close to 500 miles. Final recording before interstate clearing was 26.8 MPG. Next leg wasn't as good heading into the rolling hills of East Central OH and Western, PA Even that tank was over 400 miles so not too bad for highway cruise at around 72-76 with A/C on.
Thanks again for the assist Jaimie, keep up the good work.
