Taken from SHOTimes.com:
Adjust your brake bias: The SHO has a sophisticated front/rear brake pressure proportioning valve that not only adjust for static weight distribution, but also adjusts for dynamic brake bias while the weight shifts forward during braking. It measures stopping intensity by measuring changes in rear ride height. Fortunately, it is also easily adjustable. The ideal setting is to have the front brakes lock just 5-10% prior to the rears, ideally under all traction conditions, but dry pavement is usually the compromise. Any change in tires, springs, brake pads, ride height, weight, rotors, etc. can require a change in the brake bias to get back to the ideal. If ABS equipped, it is important not to let the ABS do this load compensating, because if it kicks in at only one end, the other end of the car is not braking at optimum. (This could be the reason some ABS cars have taken slightly longer to stop than a non-ABS version.) Maximum tire traction is achieved at about 5-10% tire slip. The hardest part about testing this setting is not flat-spotting and ruining a set of tires. (Testing ABS cars should be much easier.) It's very likely the Ford setting is more conservative than ideal, (just like understeer) and you could likely dial-in a little more rear brake to help the over-worked fronts, and improve your stopping distances. Try lengthening the adjustor rodlength near the left rear lower control arm 1/4 in. at a time, until the rear tires lock first on dry pavement. Then back off 1/2 in.
