Procedure for Replacing Motor Mounts?
SuperG
Houston, TX
After looking at the Autozone site, which Scott posted, I saw the procedure for replacing the motor mounts...is it really that easy?
SHO--ripper
928 Euro
winsted,CT
Take the passenger side wheel and fender wall out. Remove the lower radiator hose from the Waterpump assembly. Take the bottom nut off the motor mount that holds it to the subframe. slightly jack up the engine and remove the four motor mount bolts. Don't forget to disconnect the TQ. limiting mount bolts.Reinstall. Good luck.
