Problem with timing belt tensioner
OmMEGGA
Allen,TX
I tried everything but I am still unable to compress the tensioner. I dont have vice but I do have big ol' C-clamp. I used all my strength and it compressed maybe half way (the tensioner is removed from the engine) The second issue is, the piston is turned 180 degrees and even if I was able to compress all the way, I can't put the Allen wrench through...
Any work arounds once I am ready to put the timing belt on?
Off Road SHO
Moderator
The piston can rotate in the cylinder very easily. Rotate it into position first then compress it SLOWLY, it is a tensioner AND a shock absorber. It only travels about 3/8 to 1/2" so make sure pre-tension the belt using the eccentric hub of the bearing, BEFORE you pull out the allen wrench.
Tom
OmMEGGA
Allen,TX
Tom
Thanks guys!
Got it ! :wave:
