prob with fog light mod
V6&V8SHO
wauconda, IL
i hooked the 1st wire and the 3rd wire from the fog switch together and capped the 3rd wire from the dash, but the mod doesnt work. Whats wrong?
Mike Kopstain
Arlington Heights, IL
He did get the instructions from there.
John I just read it again... and we did do it right? Basically you splice the top wire, cut the third wire and attach it to the splice, and then cap the third wire coming from the dash??? :confused: Damn them womens for speeding us up. :mad:
Huntervf
Bored now
Back in Michigan ... again.
Do your driving lamps work at all, or is it just the mod that doesn't work?
Basically, just double check your connections, make sure the connection is good. You're dealing with 2 wires, blue with red stripe (wire #1) and red with black stripe (wire #3). #3 is spliced into #1 coming from the back of the switch, and the other end of #3 that goes on into the dash is the one that get's taped up. Of course make sure that the other end of #1 is connected back up to the splice you just made coming from the switch. Basically you're fooling the driving lamp relay into thinking the headlights are on by replacing the headlamp power wire with the parking lamp power wire, which of course becomes live when the parking lamps are turned on.
Double check your connections, make sure they're correct and that you have a good connection. The mod should work provided the right wires are connected...I really can't see any way that it couldn't work, unless the lamps aren't working at all.
walt
pittsburgh
all i did was cut the first and third wire and switched them over and mine works fine
Mike Kopstain
Well we did it right. I'm sure we did. Come to think of it John, Craig said that the mod didn't work for him either and when I was driving his car I made the remark about his gauge lights going out when I turned on the high beams... and he said that it was because of that. Get a multimeter and check for power where it should be, and then check the fuses and all one more time, or jsut stop by and we'll smack your car's bitch up! shoot
poffffd
