Power Steering Rack Auxiliary Acutator
94SHOgun
Massachusetts
94' 3.2. while wrapping up my 3.2 mtx swap i noticed that the vaps connector pig tail pulled out of all four ******* behind the black rubber seal on top of the Auxiliary Acutator sensor, on top of the Rack. the ******* were the wires pulled out are set towards the bottom of the sonsor and from left to right what are the colors so i can solder the vaps pig tail back in. the colors i have on the pig tail are Yellow Black White Green. in no order. please help!!!!.
Thanx
94SHOgun
Massachusetts
soooo if some one would be so kind to go under there SHO and look at the rubber boot on top of the acutator housing on top of the power rack on the drivers side. lift up the boot were the four wires are going in to and tell me the color order of those wires from left to right that wouyld be the best. this is all that is holding up my car from being complete!!!!
SHO SPD
SHO member #480
Naples, Florida
well I looked at a diagram for it and looking at the diagram it goes like this
________|________|______VAPS_____|_______|____________
wire colr GY/R .....GY/O....................P/Y..........P/LG
________|________|__VAPS MODULE__|______|____________
..........pin 9.......pin 1......................pin 12....pin 11
Hope that helps a little the diagram did not show me any pin numbers at the VAPS only at the module.
