Power steering pump whine?
SUPRDUD
NE
Hi,
I picked up a 93 ATX with 56K miles and it has a whine all the time from the PS pump that varies with engine rpm.
Does this mean a new pump is needed or some other related problem?
Any experiences?
Kens1992mtxSHO
The Commonwealth
When I picked up mine it had the same whine. I neglected it until I was 500 miles from home and it left me on the side of the road overheated with a seized pump and a snapped accessory belt. Save yourself a headache and just replace the PS pump.
jthod
Mr. Goodwrench
Lincoln, Nebraska
Drain the fluid and refil it with DEX/MERC ATF. I use Valvoline MaxLife. I'm kinda limping mine along so I can do it when I do the front 60k this summer. I drain and refil about every 2 weeks, otherwise it has little to no power.
I'd give it a try, the fluid in there probably looks like mud.
Storm-Chaser
Shit Louis
As jthod suggested, flush and refill the power steering fluid. Do a search as there are several threads describing how to do this.
In some cases it will stop the whining, sometimes it lessens it, sometimes it has no affect. It's an interim fix until you can determine if the power steering pump needs to be replaced and then locate a replacement.
:burnout:
JEM
SF Bay Area, California
Yes, change the PS fluid, use a good synthetic ATF.
A PS fluid change every couple of years is a good idea anyway.
The pump in my '92 Saab started whining at about 70K miles; a fresh fill of Mobil 1 ATF quieted it down, and occasional fluid changes have kept it that way. For 110K more miles so far.
SHOdownTN
Texas
Just make sure it's the P/S pump. Mine had a whine when I bought it, the previos owner told me it was the p/s pump. Mine turned out to be an idler pulley.
gas it
yellow submarine
+1
The idler next to the AC compressor goes bad often. The PS pump is a royal bitch to replace so make double extra sure it's bad.
projectSHO89
SHOless In St L
Sometimes the pumps whine due to air in the system. My old 89 developed a whine that sounded like I had a turbo under the hood. I ended up having to do a vacuum-assisted purge to clear the air from the system. Never heard another peep from the pump for the remaining several years I had the car.
Steve
