power steering pump issues
Broadkil
ohio, toledo
ok kids and kiddys, i goes like this
just got a 93 sho with a ATX (so its a 3.2L)
and the pump is either dead or the pully is shot
but which ever it is, its a pain in the *** :p
the steering is VERY stiff and i makes a **** of an ugly noise when she starts and the tires are turned
soooo...can a MTX power steering pump from a 89 SHO fit on to a 93 ATX?
cause i have a 89 pump i can have but i dont know (with the diffrences between the engines and all) if it will fit
SHOtimer
#2910
Santa Clarita, Ca
Yes, it will fit. Is the system full of fluid now? You might have an issue with the rack also, from the sound of it.
Doug
Broadkil
ohio, toledo
ok...well that GREAT news then as the gawd damn thing has dig into an area behind it on the block :p
it snapped teh belt and the pully is now froze in place (because well like i mentioned, it dug into the block)
dose anyone know how hard this will be to replace???/
Broadkil
ohio, toledo
i also forgot that, yes the system is full of flud and no the rack is not giving me one problem ...as seen from my previous post....i feel like such a damn idiot now :p
Broadkil
ohio, toledo
no leaks ..thats the good news, the pump is ok
but can ya replace the damn pump with OUT taking the front tire and such off teh car?
NoFlipping
Burbs of Detroit
Not that I've heard... I had to remove the wheel and the rear engine mount - then drop the engine a few inches to get mine out. It's a pain, but definitely do-able. Good luck.
SeanMc
NoMoSHO
In the MTX, it's a pain and can take many hours. The ATX is much easier as the engine is pushed forward more. Took 3 hours to just get out of the MTX, and about an hour take take mine out, and put the other one in.
