power steering is randomly cutting out on a 92.
intimdatr
Got Cams?
Jefferson City, Missouri
i recently saved my 92 SHO my dad had sitting in a feild and it has become my project and baby :) but as always there something that needs fixing, the power steering will randomly not boost. i believe the issue is either in the FAPS sensor or the rack is going out (god i hope not. just got done dealing with my bros rack on his 93 mark viii). but i just thought i asked and see what the community had to say and and if anything else could possibly be wrong that would cause this.
Thanks David
lowc
aka vapah lock
Quincy, massachusettes
first off does it happen under load or at idle? secondly welcome to the forum and the world of empty bank accounts. i ask about the idle because it we help us with diag-ing your consern as if it goes away when you rev it up then it could be a pump issue or rack if it happens at idle then there is a different way to go about diag-ing it
kevinspann
Don't take my advice.
Richmond VA
LOL FAPS sensor.
VAPS ;) a 92 sho does not have VAPS, so that is not your issue.
itwonder
VA
Unless you find a crimped hose, it's probably the rack. Not particularly difficult on the SHO.
whiteguy3
Scott MacIntire
Silver Spring, MD
It could be the rack but I believe even though you do not have vaps you may still have a PSP sensor located on the rack that sometimes goes faulty and causes intermitant loss of assist.
intimdatr
Got Cams?
it happens under all sorts of situations, i have yet to find ONE certain thing i do to cause the lost of boost. But i do notice it being more noticeable at lower speeds and RPMS yet it does not feel like it should at hight speeds. (lol yes i hit the F rather than the V it was lat and just got down spending all day working on it :p )
And we were under the impression it does have VAPS but we may be wrong and it may be the pressure sensor that is located on the rack.
As to the crimped hose ive spent some time checking for that and the only issue i can find is small indentation upon the cooler for it. it doesnt look like it would cause the close and if not total loss of boost and also it doesnt account for the randomness of it.
93rev2sev
Hockeytown
Intermittant PS boost could be as simple as belt slippage.
On the other hand, if the steering is "sticking while on center", it's the rack or subframe bushings.
itwonder
VA
One other thought. There is a tiny little oriface/check valve in the rack inlet (pressure side). It just sits in there, so you can get fish out with a pick. Maybe it has some crud plugging it up. Sometimes they get tossed away when the rack is replaced; it's not clear exactly what they were suppose to do.
intimdatr
Got Cams?
that sounds like something that is a very good idea and logical. just to make sure its the pressure inlet hose on the rack correct?
itwonder
VA
Yes, inlet side of the rack. It sits down inside the fitting on the rack, so you have to take the hose off to get to it. Nothing holds it down in there except gravity once the hose is off.
intimdatr
Got Cams?
The orifice has been removed and when driving around at normal speeds the steering seams to be smother with a bit more boost. yet at lower RPM (ie idle and coming off from stops) it still lacks any boost at all. Probably gonna order the Pressure Switch off rock auto and put it in and hope it fixes it.
Westerly, RI
The PSP sensor doesn't control boost on a non-fapfapfaps SHO, or any SHO for that matter. It's used for idle purposes.
To the OP, have you tried flushing the PS with Type F transmission fluid? That's the fluid recommended for the SHO.
If flushing doesn't help, I'd recommend checking all suspension parts with the car on jackstands. Ball joints, tie rods, and even messed up strut bearings will cause this issue. If all of that seems OK, looks like it's time for a rack.
intimdatr
Got Cams?
is it possible for the pump to be going bad? I've recently been through **** and back dealing with a rack on a 93 Mark Viii and when my brothers rack went it appear to have different symptoms. Just wondering.
Thanks, David
Westerly, RI
I suppose it is possible, but it doesn't sound like your issue. Normally when a pump fails it's due to leakage or excessive noise. I'd try the flush first (because it's cheap), and see how that works.
intimdatr
Got Cams?
i have not i will most likely be doing this soon to see what happens.
The stuff on the suspension stuff is either new or in good enough shape that it will not cause these problems. ive tugged and pulled on A LOT of stuff recently to find i needed a wheel bearing it seams snug as ever.
whats anyones opinion on rebuilding the racks? or is it even possible for something like this.
Thanks, David
intimdatr
Got Cams?
did the flush and its getting better. were starting to think the pump is isnt pumping
another thing added to the summer to do list when the motor is pulled to do the A/C.
