I thought I should let the community know about my remix of
Paul Nimz's (Thanks Paul!) High pressure power steering line leak fix.
I forgo the hydraulic hose and use a 3/8 F-M hydraulic swivel adapter instead.
Tools Required:
Drill America POU Series 3/8" NPT Tap and Drill Set, 3/8" Carbon Steel NPT Tap and 37/64" HSS Drill Bit w/ 1/2" Shank in Plastic Case
Century Drill & Tool 98512 Heavy Duty Adjustable Tap Wrench, 3/8-Inch through 1-Inch
Parts required:
1 x Brass Tube Fitting, Coupling, 3/8" Compression x 3/8" Female Pipe
1 x Solid Brass 3/8" to 3/8" NPT ****** Pipe Connection
1 x 3/8" NPT Male x 3/8" NPT Female Swivel
1 x roll of teflon thread tape
1 x Permatex 82180 Ultra Black Maximum Oil Resistance RTV Silicone Gasket Maker
1 x can of brake parts cleaner
some paper towels / shop rags
Cleanliness is KEY during the cutting / tapping process! DON'T let metal get inside the power steering pump, fittings or high pressure line - work smart!
How to:
- Remove serpentine belt
- Remove power steering reservoir
- Disconnect / unscrew the retention nut holding the High pressure power steering line to the UIM and unscrew the threaded fitting from the pump.
- Remove the power steering pump pulley (by sticking a short socket extension through one of the pulley holes and turning the shaft nut with a wrench).
- Remove the power steering pump and bracket from the vehicle, (3 x power steering pump bolts (12mm I believe) and 4 x 10mm bracket bolts).
- Place the pump in a vice upside down (Banjo fitting threaded port where high pressure line threads in facing the ground) so that when you drill the threads out gravity keeps metal flakes out of the P/S pump.
- Slowly drill existing threads out of banjo fitting port - Don't worry if there are still a small amount of threads left.
- With discharge port still facing the ground, stick the brake parts cleaner straw up in the smaller hole in the banjo fitting / discharge port and spray a small / medium amount of brake parts cleaner around thread area that you just drilled out (The goal is the wash the metal flakes out of the port).
- Release vice and turn the discharge port where it is horizontal to the ground and insert paper towel / shop rag into drilled discharge port with the goal of wiping metal flakes out of port.
- Get 3/8 NPT tap and tap wrench and lubricate tap with machine oil / cutting fluid and slowly use back and forth rotational motion to cut new threads (run tap in approximately a half inch or until it bottoms in the banjo fitting - periodically (5 or 6 times) un-thread tap and clean both the tap and the discharge port with the port facing the ground as outlined above with the goal of washing metal flakes OUT OF and not INTO the power steering pump.
- Periodically take 3/8 brass swivel fitting and oil the male threads up with machine oil and do a test fit into the discharge port of the pump.
Keep doing the cleaning, oiling and tapping steps until the tap bottoms out in the discharge port.
Once threads are cut and you have tested the fit several times and are satisfied:
De-grease the discharge port threads and the swivel adapter threads using brake parts cleaner and a rag and once free of dirt, metal shavings and oil / cutting fluid open tube of RTV silicone and place a bead around the middle of the male swivel adapter threads or wrap several wraps of Teflon pipe tape around threads and thread swivel adapter into the banjo fitting / discharge port of the power steering pump.
NOTE: if using RTV to seal the threads, let pump sit for 24-48 hours before reinstalling on vehicle and placing pump into service.
Re-install pump, bracket and pump pulley on vehicle.
With pump reinstalled and new swivel adapter threaded in, Wrap both sides of 3/8 Male to Male ****** with several wraps of Teflon pipe tape and thread ****** into female side of 3/8 swivel adapter.
Tighten until tight with wrench but do not over tighten!
Thread 3/8 compression fitting onto top side of 3/8 ****** and tighten until good and tight with wrench but again,
Do not over-tighten!
Move metal high pressure power steering line back into place, position keeper on stud on UIM and estimate where to cut the tube off at - I
cut mine about 1 inch behind the un-serviceable threaded fitting using a Dremel tool - be sure not to get metal flakes into the discharge port of pump or leave any inside the cut off line.
De-burr the end of cut off metal tube, Install compression nut and ferrule up onto the tube, insert tube into top of 3/8 compression fitting until it bottoms out, move ferrule top of fitting where metal tube is inserted and thread on the compression nut onto the fitting by hand -
This part can be tricky if the metal line / tube is not perfectly aligned! - once hand threaded, tighten compression nut with wrench and reinstall high pressure line retaining nut onto UIM stud.
Install power steering reservoir, fill with clean power steering fluid, reinstall serpentine belt and start engine.
With engine idling, inspect new fittings for leaks:
If any leaks noted, tighten fittings slightly until leaks stop - If leaks are on the threads of the 3/8 male to male ****** and tightening with engine running will not stop leaks, turn off engine, Take ****** back apart at top of the swivel fitting and wrap threads with more Teflon tape or de-grease threads and use RTV around threads of ****** fitting, re-thread and tighten ******. Rinse and repeat until everything is tight and tested and does not leak. - Turning the wheel from lock to lock will also build up lots of PSI on these fittings - If they do not leak under high RPM and / or when turning steering wheel back and fourth lock to lock then you are all set!
Tool Links:
https://www.amazon.com/gp/product/B01MFG7R5Q/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00BY7QB24/ref=oh_aui_detailpage_o00_s01?ie=UTF8&psc=1
Part Links:
https://www.amazon.com/gp/product/B000WTPZ68/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/Solid-Brass-...pID=41wTVAoA8fL&preST=_SY300_QL70_&dpSrc=srch
https://www.amazon.com/gp/product/B00INY1QY4/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
https://www.amazon.com/gp/product/B00JH0KGV2/ref=oh_aui_detailpage_o09_s01?ie=UTF8&psc=1
