JustinSane
SHO OFF
Hi guys tonight me and area 91 took a couple SHOs to the track for some test and tune, well bandito seems to be lacking in some power and I am not sure what could be the reason, the air was good tonight as was the wind, infact a few guys set personal best in MPH the absolute best MPH we could get from bandito was high 91's, now it does have a 80mm mas and lpm and we was thinking it could just be not tuned right, other then that we cant see any reason for the lack of horse power, we will be tearing into him over the next few days and checking the valve adjustment and looking to see if the timing is off a tooth , the intake is not that old so we dont think it has any built up restriction in it, the secondarys open as they should right between 3800 and 4000. the maf was cleaned yesterday and the air filter is a recently cleaned KN unit, you can see in my sig what else is done it has new taylor wires and a super coil, the car runs very smooth and the only thing i have noticed and it may not be related is in the morning you cant just start him up and walk away , you need to rev it a few times or it stalls, but once reved it idles fine. any way what im asking for are ideas on what to check. most of the other SHOs that run with us trap at least a few MPH better then 91 on basic 3.0s with minor bolt ons. any way we will be doing a mini upper 60k so we can look into the top end and see if any thing is outa spec, but any tips from the experts here would be great, thanks.
