Power Draw
Chazenabi
Chazzer
Lakeville, MN
Hey they everyone. Here is a good one. I have a power draw when I use the climate control. It's fine when I'm moving but when I come to a stop the idle drops and it feels as the car is going to stall. I have to keep the rpm's up so I dont stall out. I dont know if it will stall because I wont allow it to. I have a new alt as of April and have only put 1500 miles on since then.
I have to put in a new heater core cause mine is going out, but that wouldn't cause a power draw would it? I have a new battery since April as well. I dont remember ever having an issue with this last winter. I have had a new water pump installed in Feb. and a new starter in march and then the batt and alt. in April. If any one has had this happen or knows what might be going on, please lend some advice. Thanks.:help: :salute:
SHO-NUF93
Zombie
Jacksonville, FL
Does the air seem to blow as hard as it should? I know Escorts have a problem with the blower motors getting corroded and trashed, causing them to pull too much power, make noise, and/or seize up altogether.
Chazenabi
Chazzer
Lakeville, MN
It seems to blow as hard as it has in the past. I'm not 100% on that though. I'll check it out and repost tomorrow.
