JRA2000TL
The Complainer
I've been having problems with my 95 running unusually hot. I found the upper radiator hose leaking, so I replaced it. I found out AZ sells the wrong upper hose. I compared mine to others' at the SESHO meet. In any event, I "made it work" with the hose they gave me. We pressure tested the cooling system, and it held; no leaks.
Now, I'm thinking, I haven't noticed the fan come on. The car still goes above N but not quite to the H, although dangerously close. I go to do the EEC test to see if the fans will kick on, but the gray singe pin female connector is MISSING! In the pic below, I have the EEC plug and the ABS plug held up. The small gray plug that branches off cannot be found. I swear up and down that I've pulled codes on this car and it had it, but there's no evidence of it "breaking off". I've looked everywhere. There is a blank plug that's plugged in a connector coming off the harness that powers the CID, but that's not the right plug. The plug on the right is slightly melted; that's why it looks gray on the bottom--that's not the single pin plug.
How can I test for codes now if I need to?
Also, if it's the CCRM, does an 89 one work? I have a spare that I pulled from the j/y. How else can I test the fan?
