well i just pulled the intake upper and lower, and found that the secondaires are rusted. which i'm think i caused buy washing it off after b-12'ing it. stupid mistake number one. but fixable. but still, i don't see this causing a banging noise. lucky no stray object in the intake valves either. i took of the front vavle cover and the cams looks really good. nots a single bit of scoring. so it 50/50 now on the rear. i'm hoping for the best. i/m 95-99% sure none of the spark plugs are crossthreaded but i will check them all again. what are these "little metal rings in the vanity cover that lines the holes that the bolts or studs go through" i'm not sure what you are talking about with those.
the only good side to this? i can take a v8 sho apart in mear minutes, with out the 3/8" fuel disconnect mind you! lol keep the ideas flowing as i havent a clue.
oh i think i might know what you are talking about now. the metal cylinders in the apparence cover, that help to align the bolts. yes one is missing but it was gone when we got the car.
