Zap
I just saw this post on the TechSHO mailing list and I figured I would pass on the information for those of you (probably quite a few) that don't subscribe and might be needing a radiator replacement.
The radiator is for the 3.0 Vulcan with HD Cooling, apparently. It is a 3 row radiator, and one of the posts states that a radiator recently purchased at AutoZone even had metal end tanks! It weighs a bit, but might be more durable than the standard style plastic tanks.
GO/DAN part number 433891
The stock overflow resovoir will hang on the screws at the top, but not clip at the bottom. It isn't a real loose fit with the A/C lines though.
As always, your mileage may vary, but I figured some of you would appreciate this tidbit of information especially considering that it has metal endtanks and that could be more reliable.
