Please! Wiring Info!
S
slosho
Guest
Does anybody have info on the stereo wiring for my '95 premium sound?
95' ATX Silver Frost
Cone Filter W/ heat shield
TB coolant Bypass
Bypassed a few "PCV" line
Lighting mods
Sony head unit (el cheapo cdx-650)
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
RickieFrat
La Cosa Nostra
State of Corruption - RI
What type of info ??? Where .. At the head unit ???
1992 TAURUS SHO
Sig Pic By SHOTIME (THX)
MORE INFO AND PICS
1988 T-bird Turbo Coupe
Needs lil' work. Soon-to-be drag car.
AIM ... fst92sho
FRAT'S PERFORMANCE.COM
Your One Stop Source For ALL Your Audio Needs
S
slosho
Guest
At the amp, I want to wire in my own four channel. Thanx.
TB coolant Bypass
Lighting mods
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
RickieFrat
La Cosa Nostra
Ok .. no prob. Here is a easy fix to that.
One question .... Is the system still intack ?? Meaning, is the amp and wires still there ???
If so you can do what I did. I used the amp by-pass cable and cut the end that would normaly be coming from the head unit. Seeing you are hooking up a aftermarket amp you don't need that signal due to the use of RCAs. Then you can hook the by-pass cable to the amp, run your RCAs, power and ground.
Other than that I would have to rip out my seat to give you the colors if your system has been riped apart already. If you need the wires by color let me know. I also might be able to get in the trunk of SHOtimes and jot them down.
1992 TAURUS SHO
MORE INFO AND PICS
AIM ... fst92sho
S
slosho
Guest
Originally posted by LarryK:
you have mail.
You are my life saver, Thank you. You really helped me on the Lamp out module wiring too. Thanx a bunch!
TB coolant Bypass
Lighting mods
JL Monoblock 500
JL 2-12w3's
Rear tint
More to come.
