Please Help. Size of LCA Nuts and Bolts.
SHO_ROLLER_2
Well-Known Member
Branford, Fl
I have a 24mm socket and a 19mm socket. Seems to fit all but the nut and bolt where the LCA connects to the subframe.
So, anybody know?
:thankyou:
NEp8ntballer
cyber ninja
fifth circle of ****
I'd have to look and see what I bought but I picked up a 21MM wrench and a 3/4 fits on the other side iirc. I'll check when I get home tomorrow morning. I also believe it is a 15/16 for the strut rod nut.
pjtoledo
'ol man in the SHO
toledo,ohio,usa
many of the nuts attached to the subframe were crimped at the factory for a friction fit, makes them a bit oval, and hard to get a wrench to fit properly. 18, 21,24mm sizes are common.
Perry
rbruso
unlikely
Tucson, AZ
Pinch bolt and nut are 18mm. As are the castle nuts on the outer tie rod ends.
