slow_SHO_93
for the last couple of weaks when i turn the key to the run position my 93 atx
goes into self diagnostic mode it also dose this right after i start the car.the car idles high the fan comes on. and the cel comes on when put into gear drive or reverse the idle comes down to normal usual the engine runs rough in the lower rpm range but runs fine abought 3500 rpm mpg really suck im only get 11 mpg.today while sitting in the drive through at mcy ds the car died would not restart.i replaced the dis moduol no help. the car set for 3hrs it started and ran for 30 sec then died no restart. checked and cleaned all grounds.cps,cam sensore coil,plugs ,wires all done 2yrs ago.ialso tried a ccrm off a running car. i had d4u1 comp out of a 94 i switched back to the stock 93 comp. ican still pull codes the only code is a 172 lean code. please help this is my family car.(its hard to fit the wife and three kids in the back of a 93 cobra leaglly.)
