Adi Agaj
Guest
ok guys,
today i had my rear brakes done on my 92 SHO. I put new pads and new calipers both rear sides (no need replacing the rotors, because they were fine) The front brakes replaced 2 months ago all new pads and rotors. well so i bleded them when the job was done today. The pedal felt looser and softer then before even after bleeding them. I took the car for a ride after i finished and when i braked hard i do not feel my pedal ticking like it use to do when the abs locked all wheels up. After then i went in around all four wheels and when i touched the rotors only front left, front right, and rear right where very hot because of braking and the rear left one not even 20% of the others. I don't think is the caliper because i just put em on today brand new out of the box.
The car skided with one ( more was the drivers side wheel )or both wheels on wet roads when i intentionaly locked up the breaks. however it doesn't seem to skid with the back. Is this normal or is it an indication that the back breaks having trouble now? Also the pedal feels a bit lower. What about if there is any way how to run self test in the ABS control like there is when you do to get the codes from EEC ( electronic engine control) when your check engine light comes on ??. Anyone know where to take it from here? please any advice will be really apprecietd.
thanks
adi
rl/fr/rr/lf
<small>[ October 26, 2003, 09:46 PM: Message edited by: Adi Agaj ]</small>
thanks
adi
rl/fr/rr/lf
