Easier said than done! We ended up using the pickle fork that is used for the front control arms to pry the bushing away from the rear control arm! Only problem was that instead of the bushing sliding off of the bolt, the sleeve in the bushing separated itself from the actual bushing because it was fused to the bolt!
Once the control arms were off of the knuckles, I had to do a similar procedure (as descibed above) to get the sleeves off of the bolts themselves. Two of the four bolts that hold the control arms to the knuckles still had them attached. After about a half hour (on each side) of heat, PB, prying, and pounding, they finally separated themselves. I took a close look at the bolts themselves and at the spots where the sleeves had fused to the bolts, they were covered in so much rust and dirt it was to the point that you couldn't see the threads anymore! A good wire brush cleaning should make them good as new.
Working on car that live in the rust belt sucks.
