Pic of TB installed
SHOpride
Chicago
Pic of Throw out bearing installed
I know this sounds stupid, but I am having dobts that I put it in right. Before i throw the subframe back up i just want to make sure everything is right. Does any one have a pic of the TB installed, it would be greatly apreciated! Thanx for any help!
autobahnsho
SHO Victim
NY for now, WY for real
Sorry, I can't take pics any more.
I do have a pic of a TOB (the more common abbreviation) here:
www.photoisland.com
login id= autobahnsho
password= sho
on the left click folder= sho clutch
The TOB should be around the shaft coming out of the tranny.
The first top left pic should be towards the tranny, the second from left shoudl be touching the pressure plate fingers when you put it all together.
The shift "fork" should be connected to the little holes on the TOB so when you turn it the TOB moves. It won't move extremely well until you have the pressure plate pushing against it (after you put it back together).
Good luck, let me know if you have other questions.
poffffd
