Phenolic Spacer installs - ANY UPDATES for us non Phenolic spacers :)
SuperPete
PA
I see some of you guy installing them spacer, can you update on your findings?
Can't wait to find out...
Thank you much!
802SHO
Boost > VE, MBT, Cams
Essex Junction Vermont
Still playing tag you're it with the passenger wheel bearing....but I think today is the day she comes out. ......then I can install the new bearing/hub and reinstall the brakes...then add coolant and burp it...then I'll get some tests.
GotGrip?
Conversation Ruiner
Minnesota
I'll send you mine if you send me yours when you get it haha. At this rate it'll be two months before my manifold is done
I'm probably not gonna get one, at least not for awhile. I've purchased 2 very high dollar items recently, so I'm pretty much done with where I'm at. Then of course I woke up to water in my basement yesterday morning so there's that I have to deal with now =(.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
yowza
skyshadow07
Oklahoma
I'll probably get one. Mostly because i want to pull my manifold so I can wrap the coolant line in some kind of heat reflective insulation.
Michigan-SHO
Michigan
Didn’t MrHighCaliber do this? Or was it X-sport? Either way, it has to be beneficial. Removing ANY heat from the intake allows for denser air and more POWA.
skyshadow07
Oklahoma
I don't remember who it was but one of the threads has a post with home style AC insulation and reflective tape around the pipe that goes through. It looked really well put together so I plan on copying it.
802SHO
Just waiting on a new brake rotor dust shield for Thursday and then I can install the new wheel bearing and get it back on the road and tested
Ecoboost_xsport
Sacramento, CA
802SHO
3224BBCE 4564 4B62 8F7F F474147E2265 CB65B4EE B04F 47D7 8F9C CD1C1F5544CD 8954440C F3E2 49AB A2AB C456FDF22BF5 Well the only positive results I have are when I went to the track I iced the car down with 3 bags of ice for 35 min or so. Turned the car off and on, off and on in the staging lanes. Ran an 11.90. Then hot lapped it, was forced to run left lane only, had to wait for cars including myself to drive into left lane from right and it was slow and steady movement so left the car on. Guy in front me of me screwed up his launch they let him go again...I sat idling, then he screwed his trans up, they cleaned it up as I continued to idle. IAT2 climbed to 147 and stayed there. Ran an 11.67 after the car got hot.
In 3 Dragy runs since then all with driving around for 15 min or so prior and no cool down or anything I ran 11.88, 11.86, and 11.84 which was running last years tune, then two tune revisions. So everything extremely consistent and like I mentioned above...improved time even though the car got much much hotter.
If you consider the above it’s promising to say the least. I don’t think you’ll get a “wow” factor from the phenolic spacer...but excellent consistency
Michigan-SHO
Michigan
In 3 Dragy runs since then all with driving around for 15 min or so prior and no cool down or anything I ran 11.88, 11.86, and 11.84 which was running last years tune, then two tune revisions. So everything extremely consistent and like I mentioned above...improved time even though car for much much hotter.
Do you believe this has to do with the phenolic spacer? Or more to do with the massive up front intercooler, damn near freezing the air coming in?
Devil’s advocate of course, is there evidence of all the same modifications (minus the phenolic spacer) making a worse pass?
boaterstechorlop
