Phantom oil leak
BIGSHOMIKE
Orem, Utah
Well my oil leak has all but stopped now. It appears it used a qt the first 70 miles or so, then another in 150 or so, and the last one it used about 1/2 of the last one slowley and hasn't used mush if any last 3 or 4 days. Only explanation I could get is the problems it had when I got it, bad ETC, thermostat and wires all caused it to run rich, so all the gas "washed" the cylinder walls. Not sure what that means but now that I've fixed the problems and drivin it awhile it's going away. Not sure if that was the problem or not but I'm definatley not complaining. Thanks for all the help trying to figure it out.
billyshoe
minneapolis,mn,usa
Its burning the oil. The cats do a good job of hiding the smoke don't they. The oil control rings are stuck. coked-up. Blow-by is excessive. You are smelling it, right? You can fix leaks til' the cows come home and it will still use if this is the case.
PapaNinfas
Houston
i think i may have something similar to this....i'm not using oil half as fast, but its going quicker than usualy, i cant see smoke but i can smell it everytime i get out of the car, and there is never a visible leak....
Dr.Evil
No Dif Pin!
Sparks, Nevada
I go through a quart or so a month...only because it is leaking through the main seal onto one of the cats. Kind of sucks when you are sitting at a stop light and it looks like you have a fire under the hood eek! I need to fix it soon.
Mr Anonymous
Tire Wall
Dr.Evil:
It would suck even more if the oil finally does ignite on you! eek!
Dr.Evil
No Dif Pin!
Sparks, Nevada
Yea, it would, but it is not that bad of a leak. Can oil really catch fire? Would the exhaust system be hot enough to light it? I didnt think about that...good point. I plan to fix it this weekend anyway. :)
projectSHO89
SHOless In St L
Dr Evil
Check your cam seal behind the cam sensor. It is another popular leakage point. Mine was trying to imitate Niagra Falls....
Steve
Fireman_17
South Sioux City, NE, USA
Just curious if the Cam Seal that you are talking about is the same as all the rest of the Cam Seals? I have a leak in the same area but I'm not sure which gasket's I need in order to fix the problem.
Thanks.
projectSHO89:
Dr Evil
Steve
Yes leaking oil can ignite. Ask the guy who had a nice oil leak and made a road trip to NY. Marshmallow time in the engine bay.
I keep my used oil and tranny fluid and use it for stump burning. best thing around for starting stubborn fires without singeing my eyebrows......
