Performance Plus is AWESOME!
91 SHO PLUS
COLUMBUS, OHIO, USA
I just wanted to say Doug Mellum & company are awesome!!:hail:
I was there this week to get some maintenance work done:
Complete 60K, including new water pump, plug wires, crank sensor, cam sensor, V/C gaskets & plug well seals, & front crank seal.
New clutch kit with the correct t.o.b., flywheel machined, rear crank seal had been replaced before & was not leaking. Amsoil ATF in the transmission.
New subframe bushings, the rear bolt recall had already been done.
Flushed power steering using Amsoil ATF.
Doug installed my new Monroe QUICKSTRUTS all the way around, along with all 4 new swaybar endlinks & all 4 new TPR swaybar bushings.
Doug also installed my brand new '91 style EATC with the correct soft buttons & green lighting. (Thanks to TYSHO - Brian in Texas!)
Doug is very meticulous, & anything that needs to be done is done while everything is apart. He goes the extra mile to do the job right the first time. His knowledge of the SHO is amazing, & he really enjoys sharing it with the customer.
If you're within a days drive of Madison, WI & need some work done on your SHO, Doug Mellum & Performance Plus is DEFINITELY the place to go!!:biggrin:
Jeff Parker
Columbus, Ohio
AREA 91
PA SHO SHOP
Area 91
I also like Doug, and his business. Great to deal with. I still believe that they have the best "catless Y pipe" available! Fully stainless.:thumb:
