PBR S.S. Lines
SHO_POWER
Ontario, Canada
Dave Kegel
Chicago suburbs
No adapter. I just unbolted the rubber line and attached the SS line. I believe I had to slightly modify the mounting plate though. The stock line is kind of D shaped where it goes through the plate and the Earls lin was round.
Dave
Mr Anonymous
Tire Wall
The Earls work perfectly with the PBR's, as long as the hard line on the car wasn't reflared and refitted to fit a Cobra line. If the stock bracket is in place, then the Earls will work fine.
SHO_POWER
Ontario, Canada
Does the Earl's kit come with all 4 brake lines ? If so will the rear lines bolt up to my rear calipers on my 91 SHO ? Is there a place in Cananda that sells this kit ?
Thanks,
Greg
91 SHO +
Dave Kegel
Chicago suburbs
Yes, it comes with four lines and will work with the rear calipers. Not sure where to get them in Canada though. Can you order from Summit or Jegs?
Dave Kegel
Ishodu
Thanks,
Greg
91 SHO +
I ordered my set from Jegs Greg. Got them in about 2 weeks.
gosho89
Vancouver, WA
SHO_POWER
361-28B460 Earl's Hyperfirm Brake Hose Kits fits 94-95 Taurus SHO according to Jegs. But I found they fit my '89 SHO real nice, all 4 lines for $89.00 + freight. I also installed longer Earls banjo bolts in the front due to the thickness of the Earls hose ends. I can't recall the part numbers
http://www.jegs.com/
