parking light problem
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
ok since this is a mod the fog light switch and its becoming an emergency for me im gonna post this here in hope someone has some insight.
ok im posting this here because i guess its a perfromance mod in some sort and im calling it engine lol also no one seems to check the maintence section or the electronics for that matter
ok i got a problem with my parking lights and fog lights... i checked all the fuses first off
ok i did the fog light switch today its the trick where you can use them without the headlights on... well anyways i notice di wired it wrong by mistake... bad day dont ask...
well anyways now my parking lights dont work but the chime goes off when they are on and the fog lights arent working, i did undo and hook everything back up to how its suposed to be from the factory.
the parking lights work with the headlights on but still no fog lights... i dont know if it matters but the PIAA upgrade forlights are in the car now and i got white face guages... the guages were working fine before but now im having problems with them so i ive been messing with em and cant seem to find out how they are suposed to be...
so if someone knows how to wore them up id like the help also.
car is a 93 mtx it was an atx tho.. just figured id let all be known... thanks for any help
update... i got the foglights working it was the switch burnt out i guess
ok that sucks i figureded someone might have an idea...
umm... the bulbs are fine. the fuse in the foglight switch is fine.
somehow last night it blew the a/c fuse. and it stopped chiming all together.
im honestly lost unless i burn out some wire which i dont know how that would make a difference because everything works when headlights are on.
i even replaced the main headlight switch and nothing made a difference...
