p/s leak
.RaMpAgE.
Las Vegas, NV
well did a zf rack swap and got the rack in with mostly without a hitch filled the reservoir now its leaking, looks like out of the top of the p/s pump right where the large hose guessing return line connects to the top of the pump is there some kind of seal in there or is it a pump change are they prone to cracking cause it looks like its at the casting. Worked fine before i took the pulley and the reservoir out to get to the high prx hose....
