A-Rok
I did an engine swap in my 91, with a 91 block, so everything should be fairly straight forward.
I had the car running for about 3 weeks, when it started smelling a touch like coolant and getting a bit warm.
So I replaced the water pump which seemed to be leaking a touch, just from the gasket but put a new pump on anyways. When I filled it with coolant I could only fit 4 quarts in. I replaced the thermostat the next day, but still could not fit any more coolant in.
To check for any blockage, I disassembled all the hoses and ran water through the rad, and the block, and it seemed to flow fine through both.
Anybody had any problem like this before or have a clue what is going on?
