Opinions on this Tranny fluid...
DavidT
TN
Valvoline Max. Life for higher mileage engines (Mercon III). I am planning on changing the fluid in my mtx sho. How about 2 quarts of this and 1 quart of B and M Trickshift... (I don't have a clue...)
Also, what kind of manual vac. hand pump do I need? Would a $1 siphon pump do the trick?
olympic
Saskatchewan, Canada
I see you have a 90 MTX. If it hasn't been rebuilt with updated blocking rings, stick with type F ATF or maybe try GM Synchromesh(available at a GM dealer). The old style brass blocking rings need a less slippery ATF to work properly.
When my MTX was rebuilt, I started with Mobil 1 ATF and it didn't shift worth a darn. Ford friction modifier and even Dexon Mercon didn't help much. So I switched to Synchromesh and it shifts like butter now! thumbs_u
So the GM fluid is good for the later modle MTXs like in my 93? Do you have the part number? I am ready to change my fluid as I presume it is the OEM fluid of 150k ago.
shojuan
sunny San Juan Bautista,
Redline D4 was crap in my 89. The brass blocking rings don't like it. I'd try Redline MTL if I were you. When I finally got fed up I just used what I had lying around, I drained half the D4 and replaced it with 40% MTL and 10% MT-90. Works great.
Rick
DavidT
TN
I'm not going to fool with installing a drain plug... I would probably screw something up. Besides, I doubt I will ever change it again. But who knows.
I don't know if it has been rebuilt... for 144,000 miles I have no idea what my sho went through :(
So... type F huh. 3 qts. Nothing else?
Rick, whats Redline MTL?
<small>[ January 23, 2003, 07:52 PM: Message edited by: dkautumna ]</small>
NWGRN94MTX
Vancouver, WA U.S.A.
shojuan:
Rick
Sorry you had a problem with it. But I hardly think it's "crap". Most people in our club are running Redline D4 or Mobil 1 ATF. Even Nick Chrimes runs it and recommends it with the trannies that he does. shrug
olympic
GM Syncromesh
GM part# 12345349
GM specification# 9985648
I may have those numbers reversed though. Most dealerships have this in stock on a display shelf in their parts dept.
I read up on Redline MTL and it seems to have the same properties as Synchromesh. http://www.redlineoil.com/redlineoil/mtlti.htm So either one would be a good choice for an 89-90 MTX. If you want to save some $$, just use Type F ATF.
All of these are less slippery than other ATF's which is what you want for brass blocking rings or if you have a notchy shifting tranny.
mikiedreb
Benicia, California
Replaced my Mercon fluid with GM Syncromesh last weekend. What a difference !!!!! Smooth downshifts, no more grinding.......Should have done this long ago. 3 qts....$10.00/qt at the local GM dealer, on the shelf.
Mike
92MTX
haydenm315
Reisterstown, MD.
NWGRN94MTX:
shojuan:
Rick
I've got mobil 1 synthetic ATF in my mtx. It's getting the coldest it's been in years in Maryland. Tonight it was down to 8 degrees. I've noticed that shifts are a bit stiff while warming up. I've heard the the redline fluid doesn't thicken as much as the mobil 1 atf. Is this true?
Emerald94
Mississauga, Ontario, Canada
It's been cold like you wouldn't believe here, the past couple of week. I use D4 in my tranny case and noticed that it takes a little while before the car shift smoothly.
Disclaimer: we're talking below 0 degree F here so it may not matter what's in your tranny case.
haydenm315:
NWGRN94MTX:
shojuan:
Rick
shojuan
NWGRN94MTX:
shojuan:
Rick
That's because he's rebuilding the trannys with the later blocking rings not the 89-90 brass blocking rings. I've put Redline fluids into the transmissions of every car I've cared about. I was expecting a huge improvement when I replaced my 142,000 mile stock fluid with redline D4 a little over a year ago. Wrong. I lost the ability to shift into 3rd gear without grinding. The sad thing was that I had 3 quarts of MTL lying around for a while that I took back to the store to swap with 3 quarts of D4 because that was what the SHO community (and redline) recommended. On a whim this last summer because another shoforum member was having similar problems with an early (89 or 90) sho and D4 I looked in my garage and saw that I had almost 1.5 qts of MTL and a little bit of MT-90 lying around so I sucked out half the D4 in my SHO and replaced that 50% with 40% MTL and 10% MT-90. Made the SHO shift better than stock, more what I was expecting (but didn't get) the first time around with straight D4. Still 100% redline fluids in there, just a better choice for an early 89 with brass blocking rings and 14X,000 miles than pure D4. When I rebuild my tranny with the late version fiber blocking rings I'll try straight D4 again. Sorry for the long diatribe. I quit coffee shortly before the new year and I just had my first glass (ok, maybe my second. And they're 20 ouncers).
In case any of you have been misled, NWGRN94MTX temporarily forgot who I was: I'm probably the biggest supporter of Redline fluids on this forum! :p It's just sometimes things aren't black and white. In this case unfortunately there is a little gray area WRT fluids and SHO trannys.
