Enough to over load the suspension at wot. Posible cure, stiffer rear suspensionHaven't had it dyno'd lately, but likely hovering around 500whp...
I am not thinking it's my suspension as I've got H&R sport springs, Bilstein B6s (step up from OEM B4s), pretty stiff Steeda sway bar and stronger toe links/trailing arms. It probably doesn't get much beefier or stiffer than this without becoming a harsh ride.Enough to over load the suspension at wot. Posible cure, stiffer rear suspension
Again, you, my friend, are in uncharted waters.
That's something that is getting addressed with my race team buddy once the car is back together! Gonna do the whole slow mo analysisHow much does the front of the car come up when you mash on the gas? and what does that do to the camber?
LOL, yes, I just don't want to hog all the camber...that's just rude. I'll leave a bit for everybody else. hahaThe picture I posted, is the best looking and performing camber angle. FYI.
So I'm gettin ready to take it in for another alignment. I think I'm going to go with a slightly more aggressive camber setup.
This is mostly for "spirited" street driving with the occasional stoplight "challenge".
Going to go with -2deg. I'm currently below the recommended settings at:
FL: -0.6deg
FR: -1.4deg
RL: -1.5deg
RR: -1.5deg
Question: front and rear identical or different setup for each?
Toe in on the front gives you stability at high speeds, at the cost of increased tire wear. SCCA guys tend to run for in on the front, and a little toe out in the rears, but rear toe out is more for RWD cars.OK, so to give me a bit more traction on the front wheels for those diigggggzzzz, I'll bring the front to -1 camber and keep the back at -2 camber, sound reasonable to start with?
What about toe, any recommendations? closest to zero as possible?
