ok so i have my sho bout a week and...
johnnyrauder
first impression is its alot faster than i expected i also have a s/c marauder with 450hp at the wheels and the sho feels as fast really throws you back in the seat when you step on it. as far as the sport mode i havent mastered that quiet yet it sort of bucks more than a thought.also im wondering if it had some sort of a tune is there a way to find out if so do tell.as far as the ride no complants smooth ,handals well comfy. now im way behind the technology having two 03 cars the syinc system is great im finding new things everyday. im desperately trying to increase the run time on the remote start it only stays on for five min. so again if someone can inlighten me it would be appreciated. loving the fact that there just aren't many around when your on the road. i have already learned lots from this forum you guys have been very helpful thanks.
xFallenxCripplex
If you go thru your driver guages vehicle options I think there is one there for auto start that you can select I wonder if previous owner was using it just as a turbo timer
Also you can push the combination again to add time from the remote
Sent from my Pixel 2 XL using Tapatalk
tech10002
Kentucky
Stock they’re pretty quick, but you don’t get pushed in the seat really hard till you tune them, and you should be familiar with what that feels like with a 450whp Marauder. It’s possible you got one somebody already tuned. Try to do a 0-60 with a cell phone app with the traction control off. If you’re deep in the 4 second range, you’re definitely tuned.
johnnyrauder
ok i just looked up 0-60 apps. (having never herd of them) seems there are many to choose any particular one you can recommend?
paul bamford
Indianapolis
I have the 15 SHO also. The extended run time on the auto start is under the left hand gauge vehicle settings on the steering wheel. You have the option of 5-10-15 minutes. I went with 15 minutes.
johnnyrauder
tried it it worked thanks. now if i knew how to keep the heat settings on when i shut the car that would be great. i tried keeping the heat and heated seats on so they would be on when i start it remotely i leave them on when i shut the car but there off when i restart remotely.
Root around the manual. You can program climate control and other things for your remote start.
paul bamford
Indianapolis
There is a setting for that also. It is in the remote start settings on the same panel. You have the option to choose from temperature based settings (how cold or hot it is outside) or your last settings when you turned it off. I have used temp settings and it works pretty well. Everything turns on, seats, steering wheel heat, and defrost. Not sure if it's for all windows, mine is garage kept.
This is in the manual also. The manual is surprisingly robust on this car. I was shocked. I kicked up my feet one night and read through most of the manual and learned a ton. I highly recommend doing the same. You will certainly find something that you had no idea about before.
Enjoy all the luxury items on this car. My dad has a jaguar f-type, fully loaded...don't get me wrong, this car fully loaded is not really coming close, but it is the closest car I have driven to that so far. I'd like to lower the suspension a few inches and come close to that handling feel of an f-type.
paul bamford
Indianapolis
You probaby have it on temp settings and not last run. And since it was set to 5 minutes...that is not long enough for the car to fully heat up...therefore you never experienced jumping into a warm car.
Do the temp settings and 15 minutes...if you have the steering wheel heated...you will love it when you jump in it after 10 minutes of pre-heat.
I was going to write my response out like this, but I am pressed for time. Thank you for taking the time.
xFallenxCripplex
Yes the manual is suprisingly very knowledgeable if you have any questions you can probably find the answer in there
xFallenxCripplex
For 0-60 I use torque pro for recording 0-60 it's usually very inaccurate by seconds usually a few times It will be dead on but I think it depends on GPS signal and how many pids you are logging
Instead if I feel it's being more peppey I'll just count Mississippi's usually I'll be just over 5 but a few will be right at 5 on 90 octane
johnnyrauder
getting back to if it has a tune i forgot to mention the car has a k&n cai.i noticed that the livernois tune comes with a windstorm cai so maybe it doesnt have one. i downloaded a 0-60 app ill try it out tomorrow see what i get.
xFallenxCripplex
Having an aftermarket intake it may but highly unlikely since programmers are married to a vehicle to help keep from that happening and makes a person have to buy one per vehicle needing a programmer
Lostneye
NY
Sent you a PM with my number. I'm close and can take a look and can tell you if it's tuned.
This, once set up it works great but needs time to warm up if it's really cold. You can tell the steering wheel was on and the seats, even cooler in the summer with everything turned on.
johnnyrauder
got the info rich and left mine ill be in touch when it comes back from getting the coating
ridered74
I haven't read the manual to tell for sure, but I'm pretty sure when you have it set for "temperature", the heated seats and steering wheel only come on if the temp is below 40 outside.
shobroooo
