Liquid_force
I've done about 95% of my vehicle maintenance/repairs for the last 10 yrs now, but on no car have I ever lowered a sub frame.
I'm assuming there are 4 attachment points (driver's front/rear, passenger's front/rear) and i can just loosen the passenger's side.
It looks like the a/c needs to drop 3" or so to gain the req'd access. Will that much "tilt" place a lot of torque on the driver's side sub frame connections? Could that cause any problems?
What am I not thinking of?
I plan to place jack stands on the frame rails keeping the front tires off the ground then place the floor jack (somewhere) under the ps side of the sub-frame and loosen (remove?) the PS bolts, slowly lowering the jack until the a/c center bolt is exposed.
On the serp belt - I would expect I'll have the best access while the sub frame is lower -- maybe it wouldn't make much difference?
Is it as simple as the other fords I've worked on where you put a socket on the tensioner pulley's bolt, release tension and slide the belt off? Apparently there's a lock of some sort to maintain the unloaded condition??
