Marccus
I need to change the shift shaft oil seal (part number 7288) (say that fast 5 times ....) for the 2nd time. I changed it the first time without using any special tool to install the seal. It's been leaking since.
There is a special tool from Ford "Sector Shaft Seal Tool, T77D-7288-A". I was told that Snap-On or Matco could supply tool if you give them the correct Ford Tool Number.
Checking Snap-On, they have seal remover/installer tools and kits to install various size bushings and seals. The different size plastic seal "pushers" are not expensive, but the driver tool ($136) and remover ($50 - $80) are. eek!
I realize you can then change all seals with this kit and the correct remover/installer tool.
But does anyone know a cheaper way:
- Can you rent/borrow tool from Pep Boys, Autozone, etc?
- Any DIY tools that one can come up with?
I read somewhere that someone used a PVC pipe of the correct ID and wall thickness to apply even pressure on the seal to drive it into its location with light taps with a rubber hammer on the PVC pipe end.
Any comments/recommendations appreciated.
P.S. I also need to install new cam seals and don't want to make the same mistake of ruining them.
