turbo79
Can anyone post what the oil pressure spec. is on a 3.0, at idle (actually 1,000 rpm) and at, say, 3,000 rpm or over? I have an oil pressure light coming on at the set idle speed of 1,000 rpm, goes out when you rev above 1,200 or so, and there are only 27,000 miles on the replaced rod bearings.
I'm going to use an actual gauge (oil pressure test kit, w/fittings) to check. Any data appreciated!
Tom F.
Tom F.
