oil leaks!!!
shomtx95
wilkesboro,N.C.
about 8000 miles ago i replaced crank and cam seals with new ones (motorcraft) and a new oil pan gasket when I done the rod bearings. Climed unger my car yesterday to change the oil and what do i see, front of the oil pan covered in drops of oil(to much for comfort). i clean everything up, change my oil, crank it up to let it get warm, clime underneath fresh oil on oil pan. anyone else had this sort of experience? thought they would last a little longer.
shospeed
austin tx
Can you tell exacly were the oil is coming from?
All of the oil leaks will end up on the oil pan, you know gravity and stuff ......
Kens1992mtxSHO
The Commonwealth
Check the valve covers and all the usual suspects. As stated, all oil leaks will eventually end up on the oil pan.
93rev2sev
Hockeytown
If the "front" is at the front of the car...and not the front of the engine...then I would bet your oil cooler to block gasket is leaking.
shomtx95
wilkesboro,N.C.
no, front of the engine, new valve cover gaskets, i dont run a top time cover so i am almost sure it is not the cam seals
itwonder
VA
It's not that unusual for an oil seal to suffer an infant mortality failure. You could also have an oil pump to block gasket leak, but those are usually slow seepage. If you are having trouble tracing the leak, you could add Leak tracer (UV sensitive dye) to your oil to help.
shomtx95
wilkesboro,N.C.
pretty sure its coming from the crank seal i just cant believe it didnt last very long. oh well, i ordered new seal and waterpump today, i might as well change the pump while i am in there.
