Just picked up a 93 with 68k original miles on it sat for awhile and has some oil leaks running down onto the exhaust. Deffinately leaking at the valve cover gaskets as the plug wells are full of oil. Also planning on replacing the cam seals while I'm at it. As long as I am this far are there any other seals I should be replacing that are common leak areas? I don't want to have to tear it down again right after putting it back together. Thankyou for all replies.
-Matt
-Matt
