Deathacus
Hey there! problem is in the title. Yeah. Okay, here's the real scoop. I drained my coolant recently and, well, pretty gunky. What was green didn't look to bad but definatly some kinda oil mix. Where it's comming from? I don't know. I was loosing some coolant but I don't know if it's being burnt or was leaking out a loose hose. I got all the hoses fixed (I accident caused a bigger leak when messing with the throttle) and in that time I've retired her as my daily so she ain't getting a lot of miles. She also has a tendency of intermittent overheating, mostly during idle and low speed driving. Fan and everything works so I don't think it's an airflow issue. Oilwise, I'm losing ~3 quarts between changes, but it looks pretty healthy, no major signs of coolant contamination. I also did a combustion leak test through the rad, it passed, and a cylinder leak test, all cylinders had ~3% leak, and I could only hear a slight hiss through the dipstick tube. There did seem to be an oily buildup on the front valve cover, it's possible that it was from the undercoating (that was last fall and I'm still getting goo running up the hood) So now what? Where do I look?
Engine is a stock 3.0 MTX with 122k
