Oil change in the V8
The color of the oil depends more on how much time you spend at WOT.
Why use synthetic blends? A 5% synthetic/95% dino is a blend.....
With the small difference between semi synthetic and synthetic I wouldn't both with the semi synthetic. If you are concerned about cost then the synthetic extended to the factory 5k recommended service time is nearly as cheap as dino at a 3k OCI.
joedogg
Florida
I had to make this for class in college, so it has chincy music (required), narration (required), partner (required), and had to be 5 minutes.
Hey! I remember this! I want you to know that because of you I knew my oil filter was easy to find about a year ago.
If nobody else did, I got some use from this video.
LJRuddy
Pop lock n drop
Poaceae fields
[YOUTUBE]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/Bv3oqu4IA7c&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Bv3oqu4IA7c&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/YOUTUBE]
Lol... my wood blocks had nails in the ends of them, whoops! Forgot about that.
6.5 quarts of good synthetic oil if you use a factory sized oil filter. You can use a larger one to get up to 7 quarts of oil. IIRC It's a Motorcraft FL401 or FL-1A?
Mobil1 factory sized oil filter is a M1-209
For the love of god do not use Pennzoil.
:laugh_ti: Join us next week when Paul takes us on an intellectual journey of tumbleweeds and their relationship to prairie dogs in the riveting documentary, "Tumbleweeds, and their Relationship to Prairie Dogs."
:rofl:
metro
+1 on Motorcraft 5-30(non-synthetic) and the FL-1A filter.
You get at least another half litre in that way.
MY '99 has about 240,000km(150,000miles??)
FWIW the newer oil filters are smaller in capacity when compared to the same part numbers of old.
tardboy21
Woodbridge, NJ
ahh yes. Feeding the V8 oil monster 101. Step 1 - buy 7 quarts of oil for your mid-size sedan. :nut:
aarmel732
Crest Hill, IL
O is for oil and that is good enough for me.
AAAHHMMM NOM NOM NOM NOM NOM!
Izzmo
SHO Enthusiast
Kansas City, KS
So.. is it bad that I change oils a lot? I used Motorcraft, then penzoil (yeah I know.. it was on sale damnit!), then I went to Mobile1, then I'm about to use Castrol GTX High Mileage Synthetic Blend...
Does it matter?
